genesiss
- March 3, 2008
- 2002 sport trac
2002 ford sport trac.
I have been having an ongoing issue that started with the engine cranking but would not turn over until an hour passed. After replacing multiple parts (cam shaft sensor, crankshaft sensor, ignition pack) I am now down to poor fuel economy as the last of the issues (roughly 12 in the city and 15 highway).
I was told the issue may be the engine coolant temperature sensor going bad so I decided to replace it. I found this was very difficult due to it being a plug and locking pin design and in a very tight spot in the engine.
I tried to purchase a replacement and the parts store kept trying to insist on selling me a part with threading.
I finally found someone that figured out the issue and found the part for the 2001 sport trac had the same plug style with clip that did fit but was shaped a little different on the sensor end which I assume was due to being aftermarket.
I noticed that there were two plugs side by side and the one easiest to access was on the left and I was told the one on the right was the sensor that gave the temperature reading to the gauge.
After installing the engine coolant tempurature sensor I found the temperature gauge on the dash now will not respond and is sitting below the cold end of the gauge. Is it possible this is caused by a conflict with the sensor being made for a 2001 explorer? It is the left passenger side sensor that is the engine coolant sensor correct?
