- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
How to: - 4x4 Troubleshooting guide
4x4 not working (91-94) The purpose of this thread is to consolidate troubleshooting information in one area so people can find the correct information quickly. It is not intended to become a huge run on thread where people ask questions as this would defeat it's purpose. Questions should be...
www.explorerforum.com
2 Wheel Drive to Four Wheel Drive Conversions
How to: - 2wd to 4wd conversion
So I finally decided to do the swap and it is quite simple and can be done in a couple of days, First off you will need: 4wd transmission and a transfer case. A front and rear axles with all matching gears. Front and rear drive shafts 4wd knuckles and abs sensors. Main wire to connect the...
5R55W - 5R55E
How to: - 5R55W transmission servo piston removal
New guy here, fantastic amount of information here. I have a 03 Explorer with 150k on a 5R55W. It has the 2-3 flare issue. The plan was to replace it with a rebuild but if I can diagnose the fault I might just try a repair. So far, the pan is off and it's clean aside from some clutch...
How to: - Default Overdrive OFF modification
I've always been irked that the transmission on Ford products defaults to Overdrive being activated. Since it's not a good idea to let your transmission be hunting back and forth between direct and overdrive while you drive around town, I try and remember to shut it off. However, I usually...
Solved - 5R55E - No First Gear Problem
Hello All! Just got my truck back Friday from the dealer and I thought I'd post the part #'s of the revised transmission gaskets for those who have problems with the 5R55E not staying in first gear when the selector is placed in the 1 position. F5TZ-7C155-A Gasket - Trans Vlv Body Sep Plt...
How to: - 5R55E Valve Body Rebuild Diary
Well I have kinda finished what I have to offer on the A4LD.... the last of which are 10 years old.... so maybe I should move on....I do not have a 5R55 trannie to rebuild yet, but I do have a VB, so let me start there.... (4R70W is up next for you V-8 guys)... I am going to start by a simple...
How to: - Repair Manual for 5R55W, 5R55S, and 5R55N Transmissions
So I came across this today. Really great info with full color pictures. It's the full repair Manual. Also, it has all the OBD2 Codes at the end. I figured others on here would like to have this and I should share the file. I wasn't sure if I should post it under a different forum but I figured...
A4LD
The A4LD Rebuild Diary:
How to: - Ford A4LD transmission rebuild diary - How to rebuild Ford A4LD
Ok, if you go back far enough you will see where I was attempting some time ago to figure out a "near bullet proof" A4LD rebuild. Time, and other things got in my way, but now with 205K on my stock 92 A4LD, I figured it was time to get serious about rebuilding it. Then I hit on an idea.... why...
How to: - A4LD DIARY - PT 2
A4LD DIARY - PT 2 (W/PIX ALSO) This is a continuation of a thread on the attempt to build a "near Bulletproof A4LD". Part one can be accessed here: http://www.explorerforum.com/forums/showthread.php?s=&threadid=98027 This is the continuation of that thread - in part 1 we tore the...
How to: - My A4LD Rebuild Diary - Part 3 - Reassembly
[This is part 3 of a 4 part series on rebuilding the A4LD automatic transmission. Part 1 is here: http://www.explorerforum.com/forums/showthread.php?t=98027 and Part 2 is here: http://www.explorerforum.com/forums/showthread.php?t=101571 Each can be read stand alone, but yu will get more out...
How to: - "My A4LD Rebuild Diary - Part 3, 2nd half - Reassembly
Well finally, eh? we are going to put this puppy back together. We've rebuilt parts fit parts, and now it's time to put the guts back in and button it up. The transmission case is mounted to the engine stand once again. I'll start by putting in the reverse drum.. over my new race, and...
How to: - My A4LD Rebuild Diary - Pt 4 - Postscript
My A4LD Rebuild Diary - Pt 4 - Postscript/Ideas/Suggestions etc. The Rebuild is done... see parts 1 through 3.... Part 1 http://www.explorerforum.com/forums/showthread.php?s=&threadid=98027 Part 2 http://www.explorerforum.com/forums/showthread.php?t=101571&highlight=A4LD+DIary Part 3...
How to: - Replacing A4LD Shift Cable in Explorer
Replacing A4LD Shift Cable in a 1994 Explorer - What I learned today. Ignore the Haynes book...it doesn't work for 1991-1994 Explorers DO NOT Take the steering column apart. All cable parts are outside under the hood and underneath The column end cable retainer is a piece of plastic in a...
How to: - Project Frankentranny - A4LD / 4R55E / 5R55E Hybrid Project
This is a current work in progress, so be patient if you think this is incomplete – I agree it is at this point. First I’ll start off with a little bit of history of why I started this project and why it could be useful and interesting to others. I have a ’92 Eddie Bauer that I have...
How to: - A4LD Front Seal Info
I found this the other day and felt it was something everyone that has dealt with the front seal leak should see. "A few words about the Ford A4LD transmission: This common transmission has problems with pump bushing to converter hub damage that results in front seal "blow-out", short unti...
CV Joints
How to: - Replace Driveshaft CV joint
This is a fairly simple job requiring only hand tools and is not very difficult to do. the kit I used was the doorman #932-201 it came with everything you need Tools: Jack & stands 8mm wrench 8mm socket and ratchet head T27 torx bit Pry bar Hammer External c clamp pliers Band clamp pliers...
How to: - Clutch Switch Bypass
Hey guys whats up? I was searching for a good thread on how to bypass the clutch safety switch and was soon dissapointed that there was not much help. I then went out to the garage and started messing around with the wires and found an extreamly easy way to bypass the switch. What you will...
Transfer Case
1991 - 1994 Transfer Case Diagnosis
How to: Rebuild Borg Warner 4404 with photos
How to: Brown Wire Mod - BWM - 3rd gen
The Comprehensive Brown Wire Mod Thread (BWM)
How to: Rebuild 4x4 Shift Motor
Transmission Swap
How to: C4 D20 Swap
How to: 302 + M5OD + 4406 = 21MPG
How to: - A4ld to Manual M50D Swap - Written by 94fourdoor
This How To Thread was originally written and illustrated by @94fourdoor This is for informational purposes only and any and all problems/accidents/injuries/divorces/pimp-slaps/etc. that may occur are the sole responsibility of the person that refuses to man-up. That being said, here we go...
How to: - M50D-R1 to M5OD-R1HD Swap
Hey guys, A little less than a year ago I converted the 1991 Ex to Manual, ditching the old A4LD. The U join-t had spit a cap doing about 70 mph, and the jolt of the trunnion hitting the driveshaft cracked the back of the A4LD case/ 4x4 housing exstension. At this point I swapped in an M5OD...
U-Joints
How to: - U-joint removal and replace-how to with pics
Here is my first how to thread--hope it helps someone. Now, let's replace some u joints! Tools needed-- 12mm 12 point wrench Pliers--I used some needle nose a flat screwdriver a 7/8" deep well impact socket (optional, a length of 3/4" pipe) A mini sledge, or BFH blocks of wood --2x6 is good...
How to: - How to: Diagnose Driveshaft and U-Joint Problems
I have recently noticed on the board that a lot of people are having a hard time figuring out driveshaft and u-joint problems. The symptoms of driveshaft and u-joint failure/weakness are sometimes hard to find and takes a well expierenced person to know what to look for. I wanted to type up a...
