- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Everything you wanted to know about PATS.
SOHC V6 Timing Chain Inspection & Repair
How to replace upper intake manifold gaskets V6 OHV
Timing chain rattle resolution process - SOHC V6
SOHC V6 Torque Specifications
How-to: F250 Booster and Master Cylinder Swap
Fuel Pressure 101 - Mini-Diary Fuel Pressure Regulator Test Fuel Pump Test
Brake Master Cylinder Differences Explained (with Pictures and Math!)
Ford Explorer Engine No Start Procedure
50 Horsepower For 5 Cents............
How to: IAC valve cleaning thread
How to: Grease the slip yoke
How To: Replace Leaky Ford Explorer - Ranger Low Oil Sensor
How to: Oil Change
Ford Explorer Throttle Cable Mod for stretched cable
How to: Thermostat Change
How to: Check your fuel pressure
How To: California Smog and "Evap Test"
Axle identification guide
How To: Make your own gaskets
How to: Fuel Filter Change
Seafoam How To Video
Axle 101 Part III : All About Gear Ratios
How to: Radiator Flush
Diagnosing A No Start/Slow Start - Starter Concerns
How to: Power Steering Line Removal
How to read a V.I.N. number
Inertia Switch Reset How To Video
Alignment 101 - Now With Pictures
Axle 101 Part I: The Basics
Coolant Overflow Flush How To
Cali-state rules on engine swap
New Forum Section: Technician Corner
Axle 101 Part II: Building Them Stronger
How to: Oil Change
