- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
That OEM balancer is hell to remove, I finally swapped the parts. It basically takes two odd bolts to use a spacer bolts in place of the stock crank bolt, to pull it off. My crank bolt was so well lubricated from being off before, that it turned in with the puller shaft each time. That would not happen if it had loctite on it. Maybe next time I may add a drop or two.
FYI, my belt length ended up at 84.25", with a stock idler pulley it would need to be near 85" long. Regards,
