Here it is in detail.....
You can "splice" the harness or build an intermediate harness to integrate the two. If you "splice" all you are really doing is moving wires from one connector to another. I would not recomend actual splices. If the harnesses are not isolated through a connector you could have maintenance headaches in the future (the harnesses won't come apart).
There are about 14 circuts to integrate the main engine harness to the body harness. There are also some extra circuts that you will want to re-route. For example my rear defrost circut was removed with the original V6 engine harness. Thus it was required for me to run a lead between two body harness connectors to maintain the circut. I also ran the power leads (fused links) of the main engine harness through the Explorer power distribution / fuse block instead of connecting them to the battery.
In total there are about 22 circuts to trace down and deal with. Also make sure your GROUND connections are good and located properly or it won't work.
When I did my conversion I moved my battery to the driver side. I also moved my main distribution block and starter relay as well. I did this to gain room for my air intake and to locate my compressor on the passenger side. I also built intermediate harnesses to integrate everything.
I have a pdf file of intermediate harnesses I built to integrate my 92 explorer with the FMS Hot rod (91-93 mustang) harness.
E-mail me at
guygroves@earthlink.net I I will dig them up and send them.
Try the local library for wire harness diagrams.
NOTE: The brown 8-pin connector you mention is NOT near the MAS air sensor, but on the other side (drivers side) on the fender well. So are the other connectors you will need to integrate circuts with.
Wire Details:
BEFORE YOU START:
1) Check out my diagrams for compatability with your system - They should be correct, but check.
2) Go to the junk yard, one where you "pull it yourself" and get a bunch of different connectors as extras. You will thank me later. Besides, they come in handy if you add other accessories like compressor and lights...
You may not find the Brown connectors,there are gray ones with the same key pattern. Get at least two of these plus the other 8-pin and 4 pin connectors. They are easy to find on Explorers, Bronco's and any other Ford.
3) Buy some dielectric grease at the auto parts store. Use it on ALL engine compartment connectors to prevent corrosion (oxidation) and water intrusion.
4) Get some shrink wrap tubing, proper solder and soldering iron. Please use solder and crimp connections with shrink wrap insulation. DON'T use the crimp connectors from Radio Shack, they are too cheap and prone to failure, the insulation will fail in the harsh engine compartment.
There is ONE brown connector on the main engine harness that has circuts that go to several different connectors (one BROWN 8-pin, 2 GRAY 8-pin) located on the driver side fender well. The water temp connects through a black 4-pin connector near the battery.
BROWN V8 Main Engine Harness Connector:
Located in engine compartment, driver side fender well --> Explorer Body Harness Connector
1) EEC relay, 12V crank & run (R/LG) --> Brown connector: power on run (O/BK wire)
2) E-Coil & EECA (T/Y) --> Brown connector: Tach (T/Y)
3) Oil Pressure Sender (W/R) --> Gray Connector: Oil Pressure (W/R)
4) 12V crank Only (W/P) --> Gray Connector 1: Start Relay (P/K)
5) 12 Volt crank only (R/LB) --> gray connector 1: Start Relay Ignition ((R/LB)
NOTE: 4 & 5 are jumpered together in the original engine harness.
6) Neutral Sense switch + (LB/Y) --> Gray connector 2 (GY/R)
7) Neutral Sense switch - (GY/R) --> Gray connector 2 (B/Y)
NOTE: Neutral Sense switch - Some transmissions don't have this circut. It is NOT ESSENTIAL to run. It is necesary to extract EEC codes. You can hook it up #6 & #7 through a togle switch and leave it in the engine compartment till you need to extract codes. The default position can be left OFF. Close it "ON" for diagnostic use only.
8) H2O temp Sensor (R/W) --> Goes to a BLACK 4 pin connector located near the original battery location (BK/B)
OPTION: you can trace this wire back to the driver side of the wire harness and splice it in there (use a connector).
GREEN 8-pin engine harness CONNECTOR:
Located inside cab, passenger side wheel well near the EEC IV ECU --> original body harness connector
1) A/C Heater control (P) --> Black 4 pin connector above ECU A/C heater control (P)
2) Fuel Pump Inertia Switch --> Fuel Pump Inertia switch on passenger foot well - 2 pin socket at switch (GR/Y)
3) VSS + (GY/BK) --> 2 connections: a) Black 4 pin connector above ECU (GY/BK); b) small 4 pin connector in engine compartment driver side fender well (GY/BK)
4) VSS - ( PK/O) --. 2 connectorsL a) Black 4 pin connector above ECU (PK/O); b) small 4 pin connector in engine compartment driver side fender well (PK/O)
5) Low Oil Sender (W/PK) - NOT USED / OPTIONAL.
6) RUN ONLY HEGO POWER (GY/Y) --> Brown connector on driver side fender well HEGO power (O/BK)
**Note wire color difference
7) Check Engine Light [MIL] (PK/LG) --> Brown connector on driver side fender well Check Engine / EEC Test (T/R)
** note wire color difference.
OTHER:
I had to Add - Modify the following:
1) Wire from Fuel Pump Inertia switch on passenger foot well (PK/BK) --> engine compartment 4 pin connector on wheel well [same as VSS circut]: Fuel Pump (PK/BK)
** this completed the inertia switch circut.
2) Rear Defrost circut:
From 4 pin connector above ECU (GY/B) --> Black 4 pin connector (large) near battery (GY/LB)
** This is a heavy guage wire - higher amperage for window defroster.
3) Low Oil Sender circut [optional]:
I did use the low oil sender, but connected it from the low oil sender on the oil pan (W/PK) --> gray connector 1 on the fender well with the oil pressure and power on start circuts (W/PK)
4) Transmission Back Up light:
The gray connector 1 also contains the transmission back up light circut. You will retain this. It is a two wire set up: (BK/PK) & (P/O)
5) Above I mentioned a black 4 pin connsctor for the VSS -, VSS +, and Fuel Pump. It ALSO contains a ground wire that is connected at the battery negative pole.
6) The Main Engine Harness should have 2 power leads that connect the FuelPump Relay and the EEC Relay to the battery POSITIVE side. From some set ups,like a mustang or the FMS harness kit these are FUSED LINKS. That is, there is a slow fuse link in the end of wire harness at the battery connection. You have 2 choices:
A) Connect these links directly to the power source:
Dark Brown & Black wires [very thick] can be connecteddirectly to the POSITIVEside of the battery,or the where the positive battery lead conncets to the starter relay [whichever is closest].
B) Remove the fused link (the thick part of the wire with the shrink wrap) and connect these circuts through the Explorer wire harness.
The Black 4 pin connector near the battery [the one that also contins the rear defroster circut] also contains these circuts but runs them through the Main Distribution / fuse Block which contains the proper slow fuses.
* The EEC Relay (Y) --> EEC power relay (Y) on the black 4 pin connector
* The Fuel Pump Relay (PK/BK) --> Fuel Pump Power (BK/Y) on the black 4 pin connector.
7) GROUND circuts:
Make sure the following ground connections are GOOD.
a) Battery Negative to FRAME RAIL & ENGINE
b) ENGINE [or FRAME] to Body
c) ECU Ground (B/W) from engine harness --> Battery NEGATIVE post ** VERY IMPORTANT
After you are done you can wrap your wires with plastic wire wrap and electric tape as desired.
NOTE:
There are some circuts you can run in a more direct fashion, but you MUST make sure you connect them in the right place and and on the load side of the circut breaker. If you go through the connectors as mentioned there are "no troubles mate".
