rvaedge
- March 30, 2005
- Richmond, VA
I recently put 31x10.5 on replacing my 235 75's. My speedometer is obviously off because of the change (speedometer reading 45, ACTUAL speed about 48) and I am TRYING to figure out which speedo gear to use. I currently have the pink 19 tooth gear. Using this formula "New Teeth = (Current Teeth x Speedo Reading)/Actual Speed" which I found by searching, I plugged in the numbers (19 x 45)/48= 17.8 which would mean to correct it I would need the 18 tooth gear. HOWEVER, I called a local dealer and told the parts guy my situation and he said to go up a tooth to 20 teeth. Now I'm all confused. Does anyone know which one I would need. I assume the formula is right and the parts guy at the dealership is either clueless or didnt understand me correctly. Like I said, I currently have the 19 tooth gear, I went from 235 75's to 31x10.5, and my speedometer reads 45 when I am ACTUALLY going around 48. PLEASE HELP ME!!!
