banspy
- May 23, 2006
- Arizona
- 96 XLT 4x4
Being a forum virgin with this being my second post, I am really in need of more help. After spending countless hours reading through the posts about the flaring problem on the 4R55E transmissions I find myself at a loss as to my options.
I read Glaciers rebuild diary and frankentranny but I still have no idea where to begin. First let me say that my knowledge of transmissions is nil. I can wrench on other things but never done any work on a tranny except the oil and filter. Until I signed onto this site, I never would have tried to touch the inside of a trans.
Well to the point, while changing the oil and filter, I noticed that the internal wiring harness is frayed from rubbing. OK, maybe thats a problem! As is common (aparently), I too am having the flaring issue. It goes like this:
Flaring at 2-3, no OD. Trans goes into limp mode only allowing up to third gear. Once in a great while, it wont flare and everything is normal...for a minute until I have to slow under OD speed. Read the codes and it is coming up with PO761 (Shift solenoid 3 performance or stuck off). The flaring only happens on 2-3 and when I try to get into OD, the engine will rev to 5K RPM. Park to reverse is only slightly delayed, no other issues so far!
Here's what I've done...removed the solenoid cleaned it and taped the wiring. Same code, now I buy a new solenoid from ford at $70 along with the internal harness at $150. Replaced both, still doing the same thing with the flaring and throwing the code. (Bythe way, I also checked resistance at all solenoids coming up with about 26-28 ohms) OK...now what?
Checked the wiring all the way from the external connector to the PCM. Appears to have continuity, nothing out of the ordinary. I dont want to keep replacing parts in a hunt and peck manner to find the cause. So I guess my question is, should I just spring for a rebuilt valve body from a place like Phoenix hard parts because supposedly, all the valve body rebuilds come with the improved corrections and solenoids, or keep hunting and pecking with other things .
Of course, I also took it to the local AAMCO and they told me $750 just to drop the trans to "look inside" which would of course be included in the final rebuild bill. Notice the word rebuild before they even "looked inside" so I am not too fond of paying $750 just to have someone poke around looking for a reason to rebuild when I might be able to get away with a $200-300 part that I could probably do myself and save $2000-3000 smackers! By the way, I would much rather replace the whole valve body than trying to rebuild it myself and losing or dropping parts.
Thanks again for a great site and all the help!
