BillyBob42
- October 29, 2023
- Portland, Oregon
- 1994 Explorer Sport
Hey. I got this issue with my explorer that' seems to be getting worse. It consistently loses coolant, no external leaks I can see but it is always about a quart low on coolant. I recently replaced the radiator and all the hoses and of course it didn't change the issue. At times on cold start it has a slight misfire making me think head gasket but it does not ever get hot and when starting it with the radiator cap off there is no coolant blowing out. Here's the weird thing, on two different occasions on cold start it misfired pretty bad and was belching out what looked like steam very heavily. Each episode lasted about two minutes then it didn't do it again. There was a months time gap between them and here's the thing. After it did that there was not excessive pressure in the cooning system and the coolant level was completely full. Are these known for having head gasket issues and do the heads crack much?;The intake manifold gasket was new about a year ago. I just need a little input as to if there is something I'm.missing. there are no external leaks. I'm thinking the smart thing to do would be to get a couple heads from the pick it yard and have them checked for cracks and warpage and all the stuff needed and just replace the heads and gaskets. That way I'll have all my bases covered. Any input would be appreciated. Also, is there any tips on how to stop the dog gone oil leaks? I've replaced the rear main, valve cover gaskets, oil filter adapter o ring and it still leaks like a sieve.
