LazyDaiseyFarm
- December 4, 2023
- Peoria, IL
- 1996 Explorer Limited 4.0
My Explorer is not reaching operating temperature. Temp gauge stays completely on cold for 20 minutes and then will only just budge about a quarter way up, rather than reaching the halfway point between hot and cold on the gauge like it's supposed to. I know that the main three culprits for running cold and no heat are 1 - stuck open thermostat, 2 - bad blend door actuator, and 3 - clogged heater core, or radiator, or hose... This vehicle hasn't had a new thermostat in 12+ years, so I am assuming that is the best first option to do. I ordered one and should receive it next week. I will change it pretty soon.
My first question is: I switch between 2 vehicles, the Explorer is my winter vehicle. Before I put it in storage earlier this year at the start of spring, I had the oil changed at a shop. I've been driving it even though the temp isn't reaching operating temperature because I only have one vehicle ensured at a time and only recently realized the problem when the heater blew cold. I would say I've maybe put only 500 to 1000 miles on this oil change... But I wonder, since the oil hasn't been getting hot enough to flash off fuel dilution, and to activate the additives, should I change the oil after I resolve the temperature issue? Hopefully the thermostat cures the cold running issue, but it could very well be a clog in the system, however I would have to assume since it is running COLD that the radiator, hoses, and galleries are not clogged, but maybe just the heater core. Regardless, assuming the new thermostat solves the temperature issue, should I just go ahead and change the oil since it's been running too cold to flash off the fuel dilution and to activate the additives? I already have the oil and filter purchased (got it cheap on a Black Friday sale).
My second question is: Assuming that only the cold running temp issue is solved with a new thermostat, (although I am hoping it'll also fix the no heat issue), if she still blows cold air, would the remaining culprits only be either a blend door actuator or clogged heater core? Or is there something else that I am missing?
Thanks for any help.
