429CJ-3X2
- November 6, 2009
- Des Moines, Iowa
- '01,'02, '04 Sport Tracs,
I searched about 4 pages on this topic, but didn't find a good answer. After I bought this '04 ST in August, I tested 4WD once in the back yard. It didn't go into 4WD the first time, but eventually did as evidenced by the way it steered going back around to the driveway.
We got about 10" of snow Monday and Tuesday. Our driveway and parking area is big enough to be a pain to shovel, but not big enough to fire up the snowblower most of the time. I quickly found I have no stamina after mostly sitting quietly since Christmas weekend while battling and getting over Influenza A which my grandson brought home from daycare. My main symptoms were nasty headaches that were tolerable as long as I was as still as possible, and some loss of appetite. So, I went to plan B, and fired up the snowblower. Reverse wasn't working, so manhandling it was more work than shoveling. I had moved the '04 to make room for the snow I intended to blow, and since it was running, I moved to Plan C, which was to just drive over the snow and pack it down.
I put the truck in 4WD High, but it was as helpless as anything I've driven. I can hear the relay click and the dash lights indicate it's in 4WD High, but it isn't. I put it in 4WD Low, and it works just fine. I found an old thread where someone was having the same problem, and someone replied that they had checked vacuum lines and sprayed cleaner in the connector when they had the same problem. They seemed to be saying they sprayed cleaner into the electrical connection at the shift motor, but he kind of lost me the as he went from vacuum lines to (I think) electrical connections, and the OP never came back to say what worked.
What do I need to be looking at to solve this? More snow is on the way, and it'd be nice to have a second 4WD drive truck.
