explorerlimited50
- May 8, 2024
- Simcoe ontario
- 2013 explorer limited
My 2013 explorer is having an issue, tge driver side turn signal isn't working and neither is the hazard light function.
I've probed the socket with a test light with no luck.
I tested the wires leading to to socket with a multi meter and it seems that there is no power going to socket.
The ground at the socket showed 12 volts
Fuses are good under dash
Swapped relays around under hood with no luck
If I probe the relay socket with test light and turn on signal the test light flashes
What do I check next? I've been messing with this for a couple months with no real progress, anyone have this issue?
