Firav
- April 19, 2024
- Morrisstown, Tennessee
- 2018 Ford Explorer Basev6
Howdy y'all!
I have a 2018 Base Explorer that I'm looking to add an additional LED break light to. These lights link into the emergency lighting system that is being equipped into the vehicle. Where I'm getting hung up is how to intercept the brake light signal so that those LED lights trigger.
I've thought about directly splicing the wires leading to the tail lights/third brake light, but I've been told that causes issues with the transistors in the BCM. Then thought of possibly just installing a relay with its own independent power supply from the battery and just using a trigger wire splice to trip the relays. However, I'm not sure if that would still be enough to cause issues with that BCM.
Another option I've researched is using the trailer light connections from the towing package. The only issues I have with using that harness is that the lights would be powered when the turn signals are turned on as well, instead of it just being strictly the brake lights, and that I'd also be permanently tying up my towing package harness into that deployment (as if I'm going to tow anything with this car anyhow lol).
What would y'all say is the best deployment for something like this? I'm stuck at a crossroads and would like some input from folk that are much smarter than me!
