- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
actual ground wire to the chasis. also the drivers side has the seat belt wires but your truck will already have those, you may just need to change out the plug from your old seat so dont throw it away!
TO make seat swaps easier you can always remove the seat from the frame (4 bolts) then set the frame in and wire it up, then remove and re-install seat cushions
