Rusty Hale
- December 9, 2017
- 1995 XLT
95 XLT with 2wd 4hi 4low switch on dash. When I drive in the mornings 2wd mode I have a hard knock that feels like in the drive shaft / 4wd system. IT will knock sporadically until I get up to speed and when cold. Once warm and spinning fast knock seems to go away. Knock feels like it is just in front and to the right of the gas pedal. Used to get a similar knock when the system was not all the way out of 4wd low after getting out of the woods. I was not sure if this could be a vacuum solenoid issue and not sure how to diagnose problem.
I have had issues with the 4WD high not working or being able to tell if it is working or not as i get stuck in places with it in 4wd high that I should not get stuck. I dont use the 4wd high anymore because this issue. Would like to see how to diagnose this as well.
