Sadfordguy
- May 18, 2021
- California
- 1996 Explorer XLT
I have a 96 explorer sport 4.0 will not idle correctly at all, at idle in neutral it will start choking for a few seconds like it's running out of fuel then it will pick up and idle smoothly for a few seconds before starting to choke up again like a constant cycle of nearly dying then being fine. In gear it will stall when it starts choking. Fuel pressure holds steady at 27 psi with FPR connected to vacuum and 35 without( but doesn't idle any better). I have replaced dpfe and EGR valve, fuel pressure regulator, fuel pump, fuel filter, IAC, upper intake gaskets, O2 sensors, camshaft position sensor, injectors, cleaned the MAF, sprayed the entire intake system down with carb cleaner and didn't notice any uptick in the idle. Checked vacuum on gauge and holds steady at 15hg ( according to the gauge I used it was good). I have verified the pump is getting power. I even took it to a shop and they couldn't figure it out, granted they weren't Ford specialists. Please any help or ideas to check out would be amazing, I'm about half tempted to light it on fire at this point
