aberrant
- July 27, 2015
- 1999 Ford Explorer EB
My '99 Explorer EB 4.0 has an intermittent staring problem. It starts up fine, but when coming back down to idle RPM, it sometimes drops significantly and then dies. Doesn't happen all the time. I've been giving it a little gas each time after starting which has solved this problem, but would prefer to fix the issue.
Also, I'm averaging 13.4 MPG around town in this truck. Planning to change out the plugs and wires, but anything else I should be looking at? Trans, rear diff, and engine oil were all recently changed. I use Ford Synthetic Blend 5W30 for the motor. Should I switch to something else? I've read that changing the exhaust and modifying the air filter box can help some, but would those mods be worth it?
Thanks.
Thanks.
