AC System/Condenser? Leak | Ford Explorer Forums
CraigRK
Elkton, MD
94 Sport
Here’s my issue. Any insight into the problem or questions would be appreciated.
1994 Ford Explorer Sport (in otherwise excellent condition), AC not working. (Temperature to 97°F yesterday and forecast for 102°F today.) The system has a refrigerant leak. If I hook up a can of R134a to an empty system and run the engine, within a few minutes the compressor begins to click on and off, in very short on cycles. Then an audible hiss is heard, somewhere in the vicinity of where the discharge from the compressor enters the condenser (I think). I have tried using R-134a with UV dye, and even with the special light and glasses, cannot locate the leak. (But I can still hear the hissing – very frustrating.) No easy-to-see joints, hoses connections etc. show any sign of leakage. Judging by the hissing sound, it seems to be located behind the tranny cooler. I cannot properly see where the compressor discharge enters the condenser.
An additional clue is this odd behavior: when adding freon+UV dye from empty, the compressor begins to cycle on/off, with the on cycle time increasing slightly as the freon enters the system. (This is the normal behavior I’ve observed when adding Freon to ~empty systems.) But instead of this continuing, with longer on cycles, and rising charge (as indicated by the cheesygauge on the freon addition spout), the compressor stops even the short cycles, and no more freon enters the system, even though the cheesygauge indicates a less than normal charge (pressure) in the system.
So, here’s a few specific questions:
1) How do I tell the “factory AC system” from the “Dealer added” AC system? Parts catalogs indicate two types of systems.
2) What are the steps involved in accessing the condenser? Does the radiator itself have to be removed? Can I just remove the grill, then the tranny cooler to access/see where the discharge side hose enters the condenser? What is involved in complete removal of the condenser? Again, can this be done from the front without radiator removal?
I think that if I had better access to the condenser, especially where the lines enter and exit the unit, I might be able to pinpoint the ^&$#%&^$&^! leak. But I don’t want to do extensive work until I have parts on hand (new condenser and discharge lines), but don’t want to order these expensive parts (RockAuto has the best prices) until I know where the leak is and what the problem is. Also, could the odd behavior described above indicate a plugged system?
Apologies for the run-on post, but I could really use some help. Thanks.
CraigK
