bullaka
- August 12, 2020
- Virginia
- 1998 Ford Explorer Sport
Good day everyone. I have a 98 Ford Explorer Sport. It's a manual. I have an issue where it will intermittently not start from time to time. It shows up more when it's warm to hot outside. I can get it to start if I do the old push and pop-the-clutch technique. Here are the things I've tried so far all to no avail.
Simply as a reminder, I can get it to start if I push it and pop-the-clutch. It can no longer be the PATS as it's disabled. Does anyone have any other ideas?
- I’ve replaced the PCM valve. I’ve tried pulling the hoses off when it won’t start to no avail as that can, sometimes, reveal a bad PCM.
- I’ve tried the driver's side door key in the lock trick: turn left, then right to disarm. (PATS system bypass which is addressed further down this list)
- I’ve replaced the transceiver module in the steering wheel.
- I’ve hotwired the ignition directly to the starter.
- PATS systems fuses are fine.
- Disabled the PATS by sending it out and having it neutered by flashing the firmware. Then put it back in. That being the case no need to do the wire bypass as I've seen in some forums.It was still acting up after disabling the PATS. I checked with the person/company that did the previous point and he confirmed the flashing of the firmware worked.
- I bypassed the clutch safety switch.
