Jim Jermain
- February 20, 2006
- Madison, WI
- 00 XLS
Does anyone know what voltage I should read at the cam position sensor for a '00 4.0 OHV? My Haynes manual says at least 10 volts when the connector is disconnected from the sensor and the ignition is on run. I am only getting about 0.03 volts at the connector and at the PCM. We checked some other pins on the PCM such as the fuel pump relay and they are reading 12 volts. If it is supposed to be 10 volts or more, any suggestions on why the low voltage? I am fighting an extremely rough running situation where the engine basically won't run and if I force it to run by applying a lot of throttle, the exhaust starts to glow like the timing is way off. I checked compression, firing order, put a new crank position sensor on and still have the problem. I really appreciate any help. Truck has been done for two weeks and wife is getting frustrated.
Thanks!!!
Jim
Thanks!!!
Jim
