Postal_Dave
- July 14, 2021
- Greenville, SC
- 1996, Explorer, 4.0
I have a Crank, No Start problem with my 1996 Ford Explorer XLT and I'm testing my Mass Air Flow Sensor. The Haynes Manual says disconnect the harness connector to the MAF to test the DC voltage. It says that with the key on, the voltage going from the B+ terminal in the connector to the ground in the connector should be over 10 volts or close to the battery voltage.
From the B+ terminal in the connector to the Negative battery Terminal, I get 12.5 volts. However, I'm only getting 5.4 volts from the B+ terminal in the connector to the ground in the connector.
The Haynes Manual says that this should indicate a bad ground wire connection, so I checked the wire. I disconnected the PCM connector and did a continuity test from the MAF connector to the PCM connector pin and everything was fine there. I also checked the ground wire, to see if it could be losing voltage because of a break in the wire by running the battery's current though the wire. It came back at 12.5 volts that way. So the ground wire seems to be fine.
I'm guessing that something inside PCM is causing the voltage to drop by restricting the flow, or bleeding off the current. Do you think that's possible? Do you think this would cause a Crank, No Start issue?
Thanks for your help,
Dave
Dave
