- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
That is how it mounts! The second diagram
It is easiest to assemble it first then slide the exhaust hangers into it, but this is not always possible, sometimes you have to put it together under the truck which can be a pita, it is tight under there. 13mm or half inch speed wrench helps
You have to get the rubber bits oriented correctly so the little tabs sit inside the slots in the metal, this is the only way you can get it all to line up and start the small through bolt
