fordysenior
- October 10, 2014
- Snow elevation California
- 2002 Expl 4x4 XLT 4.6L
Hello, I'm replacing both upper front ball joints -- it still had the factory ones. And I've had to remove the upper control arm to use the ball joint press. The shims that fell were reinstalled, one each side. So, same arms, same shims, new ball joint. Alignment was fine before this procedure. Do I need to get an alignment done?. Thank you.
