mschiap
- February 1, 2008
- Del Mar, CA
- 97 XLT 2WD 4.0 SOHC
When rolling along slowly I heard a sound like something metallic, rubbing, similar to a bad wheel bearing. I looked underneath and saw the driveshaft must have been rubbing against the edge of the fuel tank (I can see the shaft is "polished") while the rest of the the shaft is quite dirty. And, the output seal from the transmission is leaking.
So I pulled out the driveshaft and inspected the U joints. They seem fine.
I then noticed the driveshaft has side-to-side "play" where it fits into the transmission tailshaft.
I am thinking that there is a bushing in the tailhousing that is worn. Should I start there? Or are there any other ideas on what I should look for or replace?
