mcgee1895
- December 18, 2022
- Wilkes Barre, PA
- 2007 Explorer Eddie Bauer
Hey guys! I just bought an '07 Eddie Bauer with the 4.0L V6. It has 133K on it and is a beautiful car, encountering two weird issues with it though.
First: There is no heat. I'm thinking this is the blower actuator which I've read about on here already but I'm wondering if it ties more into issue #2
Second: "False" overheats. Now what I mean by this is the dashboard says the temperature is reaching too hot- a buried needle on the H- but only for a few seconds and never actually impeding driving ability nor causing any physical sign of an overheat(no coolant leak, no abnormally hot engine temp)- the only sign of an "overheat" would be that the defroster actually blows slightly warm air for a few second afterwards. This first happened going up a hill where it felt like transmission was running sloppy and whole engine got loud, then the needle shot to H for around two seconds, I pulled over and then it went to normal instantly. I did not even get time to shut the truck off before it returned to normal. I think the "loudness" was the fans kicking on as I've read that on here.
It's hard to replicate the issue but it happens consistently so far, the only thing that happens before seems to be the fans kicking on and a slight "stutter" like if you had a bad coil or it needed a fuel filter, but only for a few seconds. Then sometimes it will get the overheat needle bury but it goes away without me even pulling over or turning truck off. I don't leak coolant(and have not, at all)- Oil is at normal level and clean.
I pulled these codes from Autozone:
P0304: Cylinder 4 misfire detected
P0300: random misfire
**P0117:** Engine Coolant Temperature Circuit Low Input------- This is what I'm guessing problem is, I bought a replacement and will be trying to swap out tomorrow
P0305: Cylinder 5 misfire
P0446: Evaporative Emission System Vent Control Circuit
Also pulled a U2023-20: ABS warning
I did not pull a single code related to the transmission so I don't think it is that.
Does anybody have any ideas on what this could be? I'm at a bit of a loss and was hoping someone recognized this behavior.
Any help greatly appreciated!
