Swetrid, thanks so much for confirming this... I was going bunkers trying to find this thing for days. Many in here don't make an exception as to what years and models have it, they just tell you it's there... and I've been going crazy trying to figure this out.
I'm looking for it because, my truck is having this symptom:
If the current battery (haven't tried another battery yet) had adequate charge, and even if it was very low (reading about 8 volts), the vehicle would fire up and run. It'll stay running for ever I guess. But if I shut off the engine, at that point, it won't restart, and the battery seems lower in voltage. What's weird is that sometimes it'll start the next day.
I did take my battery to Autozone and have them charge it, but when put back on the truck, the pattern described above repeated. I opened the two caps on top of the battery to find out that the liquid level in there was lower than half??? Battery is 7 years old, by the way. And oh, my battery light is not showing on the dash!
Now, I've exempted the alternator as being the problem because the vehicle stays running on it even if the battery was reading 6 volts before truck started up.
My conclusion is that my battery is not being recharged because the "fuse" to permit that had blown; or, there is indeed no fuse, but it's just that the battery acid level is too low... or the battery is plain-old garbage... again, it's an old battery.
I don't want to do an alternator job if it's just a fuse or a battery. Others have mentioned a 100-amp (blue) fuse which I cannot locate either. I happen to have all the factory car manuals, AND a Chilton's repair guide -- and I've literally scoured these books, but the highest output fuse I've detected is a 60 amp in the distribution box. There is a 15 amp "alternator system" fuse as per the manuals that is intact.
How can you guys help? Is there a mystery fuse somewhere... or should I just shoot for a battery? I would've gone for the battery days ago, but threads on the Web kept telling me there's a fuse!
Thanks guys.
