Well I recently had some 20"s given to me and I like them. I did a test mount and they are hubcentric and even looked them up online to see what specs I could find on them. The only small issue I run into is the front with center caps, they pop the cap right out of the rim. Now as I see it there are few options:
1. Try a spacer (non studded)
- kinda sketchy from what I hear and would like to avoid spacers
2. Try an adapter (studded)
- Ok in the rear, but I have heard that this can cause the front wheel bearings to fail prematurely due to the added stress.
3. Modify Hub/Wheel Bearing Dust Cover
- not sure if I can just tap at it and hope or buy modified ones?
4. Sell them, take a loss, and spend more money on rims and tires
- not going to happen as I have no money to spend.
Needless to say in short I am unsure what I can do ultimately to get the caps to stay on, as I want to have them on so I don't look like I have a cheap set of rims with no center caps.
Here are the rims and specs:
http://www.sfxperformance.com/parts/KMCKM18728512315S.htm
Width: 8.5
Offset: +15mm
Backspacing: 5.34
Hub Bore: 72.60mm
Current Tires Installed: 265/55R/20
Width: 8.5
Offset: +15mm
Backspacing: 5.34
Hub Bore: 72.60mm
