Ryan Rives
- February 10, 2020
- Madison, Mississippi
- 2002 Ford Explorer XLT
Okay as some of you may know, 6” is tops for these things. A.K.A. a 3” Body lift and a 3” Spacer lift with Btf uppers. Has anyone thought of any way to get more lift in the front end? For example you can Lower the upper control arm by about 2 inches if you bolt the brackets on upside down. Im sure you could also get a differential drop machined in which will lower it a few inches without causing issues. A ball joint spacer could take care of the bad tie rod angles. But your left with one thing now, and that’s the lower control arm, I wonder if there is any way to lower it without having to get a custom cradle. Any ideas would be appreciated.
