charlie1234
- September 18, 2011
- Annapolis, Maryland
- 2002 explorer
I just joined after seeing the post on the forum. I have a 02 explorer . I have not had a lot of issues with it ,but they are starting to happen now.it has 238,000 mile no trans problems to speak of and runs great I did have to replace 4x4 control board last DEC and that's how I found your forum. Now I have a new problem and it has happened twice. It won't start now! The first time this happened was a month ago I sprayed starting fluid and it cranked right up. I changed the fuel filter and spark plugs and cleaned the mas air flow sensor, the fuel pump worked and now its doing it again cranks but no go I purchased a code reader and it says there are No codes. I was thinking about replacing the Fuel pump maybe its not sending the firing signal. Not sure! I just I'm not crazy about spending 250 on pump just yet.So there you have it my first post and its a long one.looking forward to any suggestions
thanks
Charlie
thanks
Charlie
