New Guy looking to swap in a 4.0 sohc
dezertranger
long beach, CA
1993 ranger
Hi, im new.
my name is marcel, i live in california and i have ford ranger.
ive been lurking at two old threads of the guys who swapped in a sohc 4.0 in place of a ohv 4.0 while using the ohv harnesses and computers
looking to hopefully get more info from them or others who have done the swap. links would be appreciated. thanks!
I have no idea how many miles it has. i have a OBD1 truck with a 5 digit odometer. im not worried about the trans. theres a c4 in my truck and i have the necessary flex plate to attach it to the SOHC.
Whats up! We see you have already found Brett's conversion thread
The wiring is pretty simple, the difference between a OHV and a SOHC is the cam sensor....most years of the OHV uses a cam synchro on the back of the engine, the SOHC has a single cam sensor on the valve cover
1993 Ranger is PERFECT for this as the 93 did not have a cam sensor unless it was CA emissions....does your 93 Ranger have a cam sensor on the back of the engine?
  • Like
Reactions: imp
the computer is a manual computer that is tuned for the c4. the c4 is operated with a manual valve body. there are currently 0 wires going to my transmission and i have no check engine light.
i dont believe it does, no. ill double check when i get off work. where would it be?
got the engine in. the oil pan DOES clear the lower engine cross member on a 93 2wd frame with autofab solid engine mounts.
for anyone who cares, i started the truck today! thanks for all your help.
Top Bottom
