HOBO
- December 11, 2023
- Austin Texas
- 1997 Ford Explorer XLT V6
Hello,
I just got this new to me Ford Explorer. I have "NO" Real knowledge on this thing at all. So, I got a tone of Questions. I hail from other side "DODGE" lol. Specifically a 1989 Dodge Ramcharger. A lot of new fancy & high tech stuff going on I'm not used to. In conjunction a completely different engineering style as well. I do have a Field Service Manual coming in. I think it is supposed to be here today or Thursday. I cant remember. But any who I got some big ticket questions that need to be answered so I can make the fixes need to get the thing inspected.
Big Ticket Questions:
Number 1: The Parking Brake Lever Adjuster " Gen 2: 3L2Z-2A638-AA" or I like to call the scissors, are completely missing. They are an assembly of two per each side of the axle. Making a total of 4 parts. I was wounding if Explorer Gen 3 "924-741" Parts are interchangeable? Because a quick search for gen 2, look to be a major pain to find & seem some what expensive. From a glance they look to be interchangeable, I would like confirmation on this.
The 2nd part of this question is. What is the best way to install them? From what I have currently found is I have to open the diff, yank the c-clips, then slide the axles out to get like 6 inches of clearance to install them. That seems down right absurd to me. There has to be a better way than that.
Number 2: My ABS light is on. I have never driven with ABS before. I know what it is & what it does. But I would like to know the most common failures as to what this could be.
Number 3: I have a coolant leak. I believe that I have found it. I think its coming from a bad seal at the Thermostat. But what I want to know. What are the common places that coolant leaks can happen on this Ford 4L V6 SOCH?
Number 4: What transmission do I have? What is normally paired with the 4L V6 SOCH? All I know is I have a 5 speed with Over Drive.
Small Ticket Questions:
Number 1: Whats the biggest Tire I can put on stock? Then whats the biggest Tire I can put on with a 2 inch lift? Last I read looked to be 31X10.50X15s on stock if my memories servers me right.
Number 2: My A/c blender switch does nothing. If I set to "Max A/c" Its freezing cold. If I just set to "A/c" is screaming Hot. Things looked to be vacuumed controlled. What normally causes something like this to happen?
Number 3: My radio was not working as in "Does not have power" I checked fuses, Things look good. Then I was messing with that 12v power port on the passenger side of the center console. Putting in my USB adapter. Then boom the power for the radio came on. Worked for a little bit. Then just randomly shut back off. I am thinking bad ground, loose wire or something like that. Any ideas?
Number 4: What is a recommended "LSD" I can put in the axle?
I know this is a lot. But trying to get everything going & working for the most part before Christmas. Any & all help is greatly appreciated! Also, I can not post pictures for some reason. I'll try later in a bit. So, I can not provide further questions I have & or references to help communicates what I'm looking at.
Best Regards,
HOBO
Best Regards,
HOBO
