MrShorty
- December 27, 2001
- Spanish Fork, UT
- 92 XLT and '87 Bronco II
I've done this for diagnostic purposes without negative consequence. As noted, the PCM acts as a ground side switch, so you would simply be replacing the PCM in this circuit with a manual switch.f I was broke and didnt feel like buying another computer seeing as this one is good oterwise, Would it be a bad idea to Make overdrive manually controled by me via a switch on the dash?
