daivddd
- February 16, 2024
- San Diego, CA
- 2000 Ford Explorer EB
I get no power to the courtesy lights because the Battery Saver Relay is not functioning and pin 3 (LG/OR) never becomes hot. I’ve tried other relays that I know work but they all respond the same.
Whether in Off, ACC, or Run, no pin on the Battery Saver Relay changes voltage:
3 LG/OR – 0 (to courtesy lights)
5 TN/YE – 12.9v
1 TN/YE – 12.9vv
2 VT/OR – 0 (from GEM)
I suppose that pin 2 (VT/OR) is the trigger from the GEM and is not sending the right signal, but I haven’t applied power to test it in fear of frying something. The power pins on the GEM register correctly:
11 WH/YE (hot Always)
6 GY/YE (hot in Run)
14 RD/BK (hot in Start)
15 BK/PK (hot in ACC/Run)
If I described this well enough, can anybody tell me what I should check next?
5 TN/YE – 12.9v
1 TN/YE – 12.9vv
