TEST CONDITIONS | TEST DETAILS/RESULTS/ACTIONS |
A1 VERIFY MODULE IS A GEM | |
| 1. NOTE: Central Time Modules (CTMs) are used on two-wheel drive vehicles not equipped with power windows. Refer to CTM Diagnostics for vehicles equipped with CTM.
Verify vehicle equipment. |
- Is vehicle two-wheel drive, and not equipped with power windows?
→ YES
Vehicle equipped with a CTM, not a GEM. Refer to CTM Diagnostics for vehicles equipped with CTM.
→ NO
GO to A2. |
A2 CHECK MAXI FUSE 2 (60A) | |
- Is the fuse OK?
→ YES
GO to A3.
→ NO
REPLACE the fuse. CLEAR the DTCs. TEST the system for normal operation. If the fuse fails again CHECK circuit 1052 (T/BK) for a short to ground. REPAIR as necessary. |
A3 CHECK INSTRUMENT PANEL FUSE 25 (7.5A) | |
- Is the fuse OK?
→ YES
GO to A4.
→ NO
REPLACE the fuse. CLEAR the DTCs. TEST the system for normal operation. If the fuse fails again CHECK circuit 1001 (W/Y) for a short to ground. REPAIR as necessary. |
A4 CHECK CIRCUIT 1052 (T/BK) FOR VOLTAGE | |
| 1. Measure the voltage between I/P fuse 25 (7.5A) pin 2 circuit 1052 (T/BK) and ground. |
- Is voltage greater than 10 volts?
→ YES
GO to A5.
→ NO
REPAIR circuit 1052 (T/BK). CLEAR the DTCs. TEST the system for normal operation. |
A5 CHECK THE VOLTAGE TO THE GEM — CIRCUIT 1001 (W/Y) | |
| 1. Measure the voltage between GEM C283-5, circuit 1001 (W/Y), and ground, and between GEM C283-11, circuit 1001 (W/Y), and ground. |
- Are the voltages greater than 10 volts?
→ YES
GO to A6.
→ NO
REPAIR circuit 1001 (W/Y). CLEAR the DTCs. TEST the system for normal operation. |
A6 CHECK CIRCUIT 70 (LB/W) BETWEEN GEM C280 AND DATA LINK CONNECTOR (DLC) C285 FOR OPEN | |
| 1. Measure the resistance between GEM C280-25 circuit 70 (LB/W) and DLC C285-7 circuit 70 (LB/W). |
- Is the resistance less than 5 ohms?
→ YES
GO to A7.
→ NO
REPAIR circuit 70 (LB/W). CLEAR the DTCs. TEST the system for normal operation. |
A7 CHECK CIRCUIT 570 (BK/W) FOR OPEN | |
| 1. Measure the resistance between GEM C280-14 circuit 570 (BK/W) and ground, and between GEM C280-26 circuit 570 (BK/W) and ground. |
- Are the resistances less than 5 ohms?
→ YES
GO to A8.
→ NO
REPAIR circuit 570 (BK/W). CLEAR the DTCs. TEST the system for normal operation. |
A8 CHECK CIRCUIT 57 (BK) FOR OPEN | |
| 1. Measure the resistance between GEM C283-18 circuit 57 (BK) and ground. |
→ YES
REPLACE the GEM. CLEAR the DTCs. TEST the system for normal operation.
→ NO
REPAIR circuit 57 (BK). CLEAR the DTCs. TEST the system for normal operation. |
