RAYMONDK
- March 3, 2011
- Zebulon, NC
- 91 Explorer 08 Explorer
My 08 Limited lost most of the water and went into self protect mode which scared the crap out of my son. I didn't know what is was until I read the owners manual. The stupid thing has no low coolant warning. The leak was hard to find because the leakage runs down the bottom of the hose then back to the frame where it disappears. The culprit was the plastic "Y" fitting used to split the heater supply to the rear heater. It's located halfway back from the front of the engine on the passenger side and not visible from above, The entire heater supply is a multi-hose assembly that is made with plastic fittings and connected with non reusable molded plastic clamps. The assembly lists for over $200. and includes all the hoses and fittings; New PLASTIC fittings. No way! I took a Polybutylene TEE (copper) and 90 EL (copper) and assembled with a short polybutylene connector and jammed it in. There is very little clearance between the exhaust manifold and the frame. It took several hours to come up with the solution but I just wasn't about to put another plastic fitting in knowing it will fail again.
