supercharged 5.0 true fire 98 explorer sport | Page 170 | Ford Explorer Forums - Serious Explorations
hi everyone, my name is tim . i live in selkirk, manitoba, canada and as if this date that i am posting this, i am 36 years old.
i bought my sport in jan 05 from a local ford dealer. it had 111,000KM's on it. this is the second sport i have owned. it was sitting on the lot for about 8 months before i came along. i am the third owner (i was able to track down the person that traded it in, and they got it from a friend, who bought it new in 98).
i started to do a few things to it after i first got it, then i found this site, and all hell broke lose! i've never been satisfied with something the everyone else has, so i started to tinker with it even more.
mods include
interior
installed factory tilt, cruise, overhead console, auto dimming mirror, full length console, with a message center (it didn't have these from factory).
white face with blue flames indigo gauge covers (they light up blue)
blue l.e.d. everything
white l.e.d. interior lights
Kenwood DDX392 Touch Screen Head Unit
alpine 4 channel amp (all four speakers)
boston acoustic front and rear speakers
alpine mono amp (for sub)
2 12 inch jl audio subs
rockford fosgate cap
passenger side one touch window down mod.
custom transfer case shifter
tripple a pillar gauge pod, housing autometer boost, Innovate LC-1 wideband, and oil pressure gauge
12v power inverter with 120v plug in a 2 usb plugs built into the center console
exterior
BMW E46 projectors, mounted into stock housings using clear lens
6000K HID head lights
angel eye "driving" lights, with 8000k h.i.d.'s
clear parking/corner lights
billet grill (powder coated by Turdle)
blacked out ford emblems
custom front steel 95-98 bumper, with 4 inch round tubes welded in for driving lights
shaved radio antenna
shaved roof rack
black euro tall lights
l.e.d. license plate lights
smoked out 3rd break light
lund rear tailgate spoiler/wing (formally from the truck "blackjack" owned by EF member Spas)
hand made roll pan (made from 3 1/2 rear bumpers, with 1/4 inch diamond plate on the top, and it is removable)
aluminum T/A differential griddle/cover (powder coated by Turdle)
Motegi Mr107 20' rims
goodyear wrangler hp p245/50 r20
1 1/4 wheel spacer in the rear, 3/8 in front
and most noticeable, black with blue pearl paint, and blue true fire (ground effects are black with blue pearl as well)
Suspension
2 inch lowering blocks in the rear, reverse TT in the front (2 inch as well)
Explorer Express rear sway bar
4 door leaf springs
rancho rs9000 adjustable rear shocks
03-05 sport trac spindles with drilled and slotted rotors
performance
5L swap
347 stroker
TFS twisted wedge alum heads
comp gold 1.6 rockers
comp cams CCA-35-556-8 nitro cam
heavily modified edelbrock victor jr air gap intake (which serves as a valley pan now)
eaton m122 supercharger (metco 2.70 pulley, and ASP 8 rib 7 1/4 crank pulley) with custom made mount with bell intercooler core
8 rib serpentine belt conversion using pulleys from a 7.3 powerstroke
custom made 3 1/2 inch throttle body elbow
accufab 75mm throttle body
4 inch intake pipe
PMASS MH90 90mm Universal 3000 KG/HR MAF
amsoil cone filter
F.A.S.T. 60lb injectors
edelbrock fuel rails, trick flow specialties fuel pressure regulator with summit racing fuel pressure gauge
walbro 255lph fuel pump
1/2 inch steel braided fuel pressure line from tank to rail using 8AN fittings
torque monster headers
2 1/2 duel pipes with flowpro duel in and out 2 1/2 single muffler
accel extreme 9000 ceramic 45 degree plug wires with boot protectors
4R70W w/2600 stall with J mod
tuff stuff 200a alternator
tuning made possible with sct pro-racer package, and tuned with major help from member [MENTION=102869]Dono[/MENTION] and [MENTION=81804]4pointslow[/MENTION]
flex a lite duel 12 inch electric fans
big 3 upgrade (4 gauge wires)
meziere innercooler water pump
2 froozenboost innercooler rads
Transfer case
4406 manual shift from a 97 F150
modified stock trans cross member to accept 93 mustang 5L polyurethane tans mount
double cardan rear drive shaft
because of all the "fun" i had doing the bodywork, and some other things to my truck, i have nick named it "evil dora" or if you like, just plane "evil"!
and now the thank yous
my buddy gord leiss, who let this thing sit in his garage for 3 months while i did the body work to it. he also gave me a hand with some of the prep work, and painted it for me
kevin willson for doing the true fire http://affordableairbrushing.ca/
Joe Bukoski for letting me do the 5L/4406 swap in his garage
now people from this site, weather they knew it or not, they helped
BIG THANKS to tara a.k.a. explorersport77 for pictures of her truck. wouldn't been able to build the roll pan with out them!
ExplorerSport77's X "Hotness"
jon a.k.a. Turdle for selling me some real swanky rear shackles, as well as powder coating the diff cover and sending them up to canada. as well as much needed info on v8, and 4406 swaps as well as doing the grill and showing me how its done.
don aka dono for the help with the tuning, and wideband, as well as the supercharger
andy aka ahodges for some parts, and any help i needed for all the go faster goodies
5.0 swap - w/ 4406
jad2411 for finding me a link for my hidden antenna
ryan a.k.a. MustangP51 for doing his write up on making l.e.d.'s for interior lights, and how to make projectors
P51's HID Headlight (Projector) and Fog Conversion (PICS)
and N3ELZ cardomain page for L.E.D. switch and cruise pod mods
http://www.cardomain.com/ride/296394/2002-ford-ranger-regular-cab/page-6
http://www.cardomain.com/ride/296394/2002-ford-ranger-regular-cab/page-12
http://www.cardomain.com/ride/296394/2002-ford-ranger-regular-cab/page-23
bob a.k.a. rwenzing for showing me speedhut's sit for the gauges
Gauges, Custom Gauges, Tachometers, Speedometers, Shift Light, Pod
Buzz4x4 for his write up on blacking out ford emblems
How to Make Your Own Custom Ford Emblems
the late aldive for his write up on one touch down passengers window mod
http://www.explorerforum.com/forums/showthread.php?t=141027&highlight=touch+passengers+window+mod
BIG COUNTRY, for his write up on how to install a auto dimming mirror
http://www.explorerforum.com/forums/showthread.php?s=&threadid=84968
BIG COUNTRY, 98formulaLS1, and Ryon40 for there write ups on how to install a message center
http://www.explorerforum.com/forums/showthread.php?t=225017&highlight=BIG+COUNTRY
http://www.explorerforum.com/forums/showthread.php?t=80670&highlight=message+center
http://www.explorerforum.com/forums/showthread.php?t=245085&highlight=Ryon40
MountaineerGreen for his 4406 swap write up and "Custom" Driveshaft for a 4406 and 4" Superlift on the Cheap " (even tho its lowered
http://www.explorerforum.com/forums/showthread.php?t=166726&highlight=awd+4x4+swap
http://www.explorerforum.com/forums/showthread.php?t=185232
Simon, aka blueka for his "pickle" thread, and help anytime i picked the phone up the phone on the 5L swap
http://www.explorerforum.com/forums/showthread.php?t=271813
Jon, aka 4pointslow for any MAJOR technical advice i have needed
http://www.explorerforum.com/forums/showthread.php?t=219092
i wish i could find who did the write up on the overhead console install, but here is the link
http://www.explorer4x4.com/overhead.htm
Russ aka NICE59FORDF100 for his help on the wiring, and what to watch out for electronically.
hopefully one day, i will be able to help people on here just as much as the people that i have mentioned above!
picture.php
plus you know you have done something right when.....
your truck (as well as corkey) wins truck of the month
http://www.explorerforum.com/forums//showthread.php?t=296023
is the feature truck on the fun hump day radio show (starts roughly around the 30 min mark)
http://explorerforum.podbean.com/2011/03/23/19-vroom-zoomboom/
and you drive 26 hours ONE WAY to the carlisle all ford nationals in june 2010 and 2011, and grab second place in the s.u.v. all category!
then in 2014 you go back to the same show you have been to 5 years in a row (nothing by most, but its one hell of a long drive) and take first!
its been a busy weekend. got the heater core done, i also did some cleaning and moving around my hoard pile of parts in my shed. today i was going to kick back and take it easy, then my phone rang which lead me to go get this.
i got it fitting real nice, but when i put the weather strip on, and the latch, it kinda threw it out. i also didnt notice, but i will have to make a extension for my pinch weld at the cowl. to big of a space. i will have to fiddle with it some more, but i will do it later.
if you look at the back edge, it sits a little high. will deal with that this week when i have some more time.
also when i went to pick the hood up, he had a car sitting in the both with a cover on it.
"guess you didnt see this the last time you where here"
"what is it?" he rolls the cover back and there is my bother in-laws fathers 62 t bird.
"they are coming to pic it up today, should be here soon"
i forgot his dad is selling off his cars because they have their house up for sale, and no longer have storage. so if you are able, on Thursday it goes up on auction.
Progress looks great!
I'm really interested to see if you can get the back of the hood to sit down. I tried everything I could think of and settled for a little offset on mine.
Can you slot the hinges where they bolt to firewall and move them down 1/4”?
∆ makes sense
that was the first thing i did. it did help. i will take the weather strip off, and bend the pinch weld down a little and see what that will do next.
It looks awesome! I'm sure you will get it sitting and looking the way you want soon.
