bleoh
- May 28, 2009
- Maryland
- '03 Explorer
So the other day my wife says she adjusted the AC and something went snap and cold air stopped blowing out the vents. I searched on here and decided to check the operation of the blend door, the blower resister and the vacuum lines that control the doors.
Well, I was able to make it blow warm and cold, so the blend door seemed okay, I could adjust the speed of the blower and hear it change, so the resisters were okay. All the vacuum lines were attached and looked to be in good order, but only the feet seemed to be getting good airflow. Then, with the glove box out of the way I noticed this:
That arm is supposed to be attached to the vacuum motor. The arm can easily be moved (with the fan on low/off) by hand and allowed air to flow from the dash vents. I am not sure what caused it to break. If it got jammed or just the force of the fan on high over time caused it to break.
I could not find the part that fell off anywhere. If someone could snap a picture of it I would appreciate it.
So, what can I do about it? It looks like it would be a real pain to get to that part of the system and replace the door, or to even cut it out and patch it like the blend door work-around fixes.
For a temporary fix I cut out a piece of sheet metal about 1" wide by 1.5" long. Then cut a slot in it to fit over the broken piece. I slid it on and bent the edges around to the back to keep it from sliding off. Any better ideas would be great. Thanks.
