dvdswan
- June 6, 2021
- SEATTLE
- 2002 ST 4WD Premium
Just picked up this 02 Sport Trac w/ 122k on the clock. Pretty stoked about it. I've been looking for either a 2dr Explorer or Sport Trac and came across this one. Some minor issues to fix but what isn't there on a 21 yo vehicle.
XLS (assuming since it doesn't have XLT on the tailgate) 4WD D2 axles, 255/70R16s all the power goodies except sunroof and cloth seats.
So, list of to do items...
Mirrors not working - Fixed post #32. Replaced power mirror switch.
Learn how to operate the 4WD, either I was doing it wrong or it's not engaging - Fixed post #28. Fat electron theory at fault. Disconnected reconnected 4WD selection switch, problem solved. Slight corrosion on contacts not allowing fat electrons through connection.
Replace tensioners - On hand.
Replace T-stat housing - On hand.
Replace Body mounts - On hand.
Change fluids and filters - in progress...
Replace bad bulbs - On hand.
Replace broken fog lamp - Fixed post #35. Replaced both fog lamp housings w/ bulbs.
Antenna missing - Replaced with new antenna.
fix wiring to topper (definitely hacked) - Temporary fix post #32. Repaired broken wire at butt connectors.
Repair radio stuck in Espanol - Fixed in post #23. Followed video.
Tailgate lock cylinder won't turn (discovered 2/2/24) - Fixed in post #57. Lubed lock cylinders.
and a jack (missing) - Found / Bought, junkyard left one in vehicle 4/2/24.
Plans...
Exhaust
Lift/Tires/Shocks
Winch
Backup lights
Roof rack cross bars
Looking for tonneau cover, bed separator, and bed extender - Post #38 Picked up Tonneau cover, bed separator, and bike rack. Post #44 installed. Post #59 bed extender picked up and installed.
Maybe a push bar with lights
CB/FRS/GMRS Radio
Put together off-road recovery kit
add-ons -
Transmission flush and filter change.
Turn signal switch swap. - Post #60 Completed.
Double Din radio with back up camera - Tailgate handle w/ backup camera beginning of install post #92 6/1/24. Ran wires for power actuator for tailgate lock.
Power Mirrors with heat and puddle lights - On hand.
Backup lights - On hand.
Power actuator for tailgate
I'm sure there will be more to come.
Repairs...
Alternator, tensioner, idler pulley, and serpentine belt, alternator bearing was making noise - Replaced post #68 4/15/24.
Replaced gas cap leash - Replaced post #68 4/15/24.
Oil pressure switch - Replaced post #72 5/3/24 with video by TRQ.
Brake light switch - Replaced post #72 5/3/24 with video by TRQ.
Driver side window glass shattered - Replaced post #91 5/31/24.
Door sticker and VIN decoded in post #19
Door sticker: -
EXT PNT: Paint Code: FL - Medium Toreador Red / RC(Region Code): 74 (Seattle) / DSO (Domestic Special Order): (?)
WB (Wheelbase): 126" / BRK (Brake Code): 4 (4 Wheel ABS)
/ INT TR(Interior Trim): PT (P is Cloth bucket w/ adjustable head restraint and 6-way power seat)(T is Dark Graphite)
/ TP/PS (Paint Stripe Code): blank is none / R(Radio Code): 1 (?)
/ AXLE: D2(4.10 w/ Limited-Slip) / TR(Transmission): D(Automatic 5 Speed)
/ SPR(Spring Code): 12(1 - 5B326 (RH), 5B327 (LH) torsion bar)(2 - no info found yet)
/ 1S11A405: Calibration Code (?)
VIN: -
1FM - Ford Motor Company, USA, multi-purpose vehicle
Z - (Brake Type)(haven't found) (usually the hydraulic system size)
U77 - (Vehicle Line, Series, Body Type)
E - (Engine Type) 4.0L EFI-SOHC, six cylinder
7 - (Check Digit)
2 - (Model Year) 2002
U - (Assembly Plant) Louisville
B85791 - (Production Sequence Number) A00001-E99999 — Ford Division
Plans...
Exhaust
Lift/Tires/Shocks
Winch
Backup lights
CB/FRS/GMRS Radio
add-ons -
Repairs...
Door sticker: -
VIN: -
7 - (Check Digit)
2002 Ford Explorer fuse box diagram - StartMyCar
www.startmycar.com
