Hartman
- October 16, 2001
- Indianapolis, IN
Hey guys, I'm a little confused about how the ABS system on a 2WD works. According to Ford Part Network's diagram, there is a sensor ring that goes on the spindle between the inner wheel bearing and the rotor. I got that part, but it doesn't seem to fit correctly between the bearing and the rotor. On my 2WD rotors, there's a little ring already pressed in there for the ABS system. My question is, do both of these rings work simultaneously, or is only one of the rings neccessary? Pictured below is the sensor ring on the left and the rotor with the ring already in it on the right.
