410Custom's builds a 2007 Ranger V8 - custom truck build - Project "Ranger Premier" | Page 51 | Ford Explorer Forums - Serious Explorations
heading to work on “blue” as she has come to be known around here.
Make it sound like the truck has been a part of the family for several generations.
It’s been front and center of the shop for almost as long as I have been in Idaho! We also feel like @EddieMoney is part of our family and we have only really met once
Okay okay I’ll come clean I parted the whole thing out and fled to mexico in my now highly upgraded b2!!!
Eddie will be driving his ranger way before I’m back in my bronco and my wife is back in her FJ… both have been parked for a year in need of dire attention. Priorities!! Blue comes first
Now we're getting somewhere.
Nice. Are you going to use the tailgate or just bracing for the bed sides?
His factory tailgate and fuel door will be going back on as well as his bed mat.
The interior of the bed will get line x and all undersides of the bed and glass are being coated with spray on bedliner
All metal edges cleaned up /treated before the glass is installed. I also have to put his 07 bed wiring / tail lights into this 02 bed
All the details are coming but for now
Time to get to work
I am not a “good sick” I cannot stand to sit around on the couch for days at a time it drives me insane… but my 51 year old body wouldn’t let me
I am super super excited to actually drive this thing. Nerves are wrecked, but luckily for me I am used to being the test dummy for first drives like this. I’ve been through it so many times. It’s like standing in line at a very scary rollercoaster knowing you are up next
Totally understand. I can go about a 1/3 of a day before I'm fed up of lying there and just force the sickness of with work outside. Pushing 60 (holy crap) and thankful I don't get sick very often. Worst one was just before Covid hit and I slept and drank grapefruit juice for a day.
Oh and i had to look up the word “tantric”
gross that you used it in a sentence
But fits the situation
Climax is coming (no pun)
Felt compelled to use both “tantric” and “happy ending”, cause, you know . . .
Get back to work!
Get back to work!
I noticed, and it took all my will power not to make a comment about it.
1st drive in my '74 Ranchero after my mechanic friend, Sam, finished the 472 (bored 460), back before people were doing much with 460s, went like this - started it up and let it run in the shop for 20 minutes while we checked for leaks and he fine tuned it. Sam got behind the wheel for the test drive so he could get a feel for how it was running and what adjustments might be needed. We went down the street to the shop of a rival Ford guy who knew Sam was building this engine. Sam turned the corner and did a big burnout. I was sure my brand new engine was going to blow before I got a chance to drive it! We headed out of town, looping around to the main highway. On the way back, he stopped on the highway in front of a mini golf course and did a bigger burnout than the first one! On that first test drive, he probably revved that brand new engine higher than I did in the nearly 25 years I drove it after that. Of course, we both knew who was going to fix it if it broke.
Some updates before she can leave this shop and head to the town shop for final testing, setup and polish we needed to finish a few major things
First she was pushed outside and washed again
The rear bumper and hitch install not easy
The Kartek shackle flip brackets live directly where the hitch used to mount. They are also right where the factory bumper brackets reside.
Much thought and then some cardboard templating and I have them fitting
The hitch will actually be welded to both Kartek brackets so basically the rear spring hangers are also the hitch. The hitch acting link a rear crossmember keeping things tight and straight.
The bumper brackets had to be “windowed” to clear everything, now factory bumper can bolt in and out. These pics from mock up all parts cleaned, prepped welded painted and then re installed
At this point the rear king shocks were final
Installed as well as the driveshafts
Brakes are plumbed, air line for the arb locker went in, the e brake cables are being fabricated and more
You can see the exhaust tail pipe also being mocked up. A $30 aftermarket ranger tailpipe was used as a guide
Fog lights final mounted tight, drivers broken mirror glass replaced, winch final wired, lots and lots of little things happening
First up the tow hitch
Lots of metal had to go away as the Kartek spring hanger is where the hitch used to mount
Template was used to make the marks after careful
Measuring then things cut out with grinder and surfaces prepped for welding
This is how the hitch will clear the bracket before it is then welded to the bracket
I have a spare set of Kartek hangers as my next project will also be setup with this rear Chevy 63” spring and inverted shackle
Test fit off the truck
Now the bumper she needed a large window cut on both sides
Small plate will be added back for strength
That’s how she fits
Now to transfer to the other side
Bumper hitch finally dry fitted
Fun to do by yourself! My arms got quite a workout here
My brain and the grinder also had quite a workout for this one, there is a lot going on at the end of the frame horns now! Really happy with how this turned out
So I turned my attention to building twin custom tailpipes. The exhaust has been 2.50 up to this point and is 3” where it exits the spintec mufflers. I will be necking down to 2.25” for the tailpipes
The aftermarket $30 tailpipe I ordered is kinda “chincey”’origialnally thought I could save some work by using bits from a couple of these but I don’t like the kinks and the pipe is like 1-3/4 in places. So I simply used it for Mock up. Don’t worry plenty of rangers come through this shop that will need a new tailpipe. The parts will get used
And the start of the tail pipes
I love my mini Milwaukee band saw!
Lots of plumbing wiring and little brackets to fabricate, final touches
Stay tuned
She’s running driving stopping shifting test phase
Shotgun exit!
Tail pipes un bolt from mufflers
They also un bolt from each other
Easier for final weld
Hitch is welded to the rear shackle hangers
All exposed surfaces welded brackets prepped and painted
The hitch now has 14 bolts that holds it on :)
Tailpipes removed and final welded
