chefduane
Texas Elite Explorer
- January 22, 2013
- Location
- TEXAS!
- Plano, TX.
- None: SOLD 9/16
Just completed front & rear sway bar bushings and end links all around. OEM bushings on the rear and Moog end link kits in the rear. Went for a test drive and really did not notice any difference. Then I did the fronts. Used Moog sway bar bushings (the blue ones) and Moog Problem Solver end links w/ the larger 7/16" bolt and swapped the Moog blue bushings for Energy Suspension bushings. >Significant< difference! MUCH less lean on hard turns and waaay less plunge on hard braking. Did a test drive and then snugged up the front end links a bit. I am very happy with this set up! The ES bushings do need a bit of a shave on the raised shoulder radius to fit into the sway bar at the top and the lower control arm holes, but other than that no issues on install. Two thumbs up for this setup and shout out to swshawaii for the recommendation.
Chef Duane
Chef Duane
