- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
I make brake and fuel lines all the time I do not see a huge challenge here. The reverse metric bubble flare Ford used at the brake master cylinder can be interesting to build, but totally do able with a simple flare tool
If you look at your truck chances are there is a union on the brake line already back by the fuel filter, Ford did not use one section of line from the abs pump back, it is in several sections.
Deleting the ABS pump, going hydroboost and get rid of the vacuum brake booster, relocate the rear axle brake line, re locate the fuel line, hack into the EVAP vapor line and you just made more room on the drivers side for keeping the exhaust inside the frame rail.
