david56780
- May 17, 2012
- 2003 Ford Explorer
I just got finished installing my new fuel pump today and the Explorer ran fine for 2 or 3 starts then cranked but no start. I didn't hear the pump priming (I have a nice hole in my floor so I can hear it well). I tried starting it a few more times and then heard the pump prime and it started up just fine and the pump sounded good on the drive home.
Then I tried to start it up again after a wash and the same issue. No pump prime.
I have checked/swapped relays and fuses with no change, I can feel the FP relay click. Disconnecting and reconnecting the battery did nothing. PATS light goes solid for 3 seconds then goes out when trying to crank as normal.
The only thing I can think of is bad wiring/connectors.
I replaced the pump because of this issue, and from what I can tell, if the pump isnt bad it will be soon as the strainer looks pretty much clogged.
FWIW I do have leaking injectors due to missing O-rings on one or 2 from when I replaced the valve cover gasket.
I can think of nothing else and she's got me beat for the day.
Any ideas?
Dave
(I should add that I have done many searches on this with nothing useful)
Any ideas?
Dave
