When I go over a large bump I am getting a creaking sound. Is this more likely to be a spring or a shock? It is not a big deal but it is kind of annoying.
It is substantially more likely to be a spring than shock, but where is it coming from? I think the most likely things to "creak" going over a bump would be the front sway bar (rotates as a tire lifts) or the rear leaf springs.
My 2002 limited does the same thing. I found a quick fix to be to lube the front bushings (i think they were on the a-arms). Even wd40 would work for the time being. The squeek for me is mainly in the winter when its really cold. Try that before you go replacing anything.
My 2004 is doing the same thing. It's coming from the front of the vehicle. I can press down and hear the creaking on both sides. I think I'll try the WD40 suggestion from Rhyno.
