i dont think they hit 500, if it does... erm... theres a huge issue!!! i thnk its normally like a hair over 200, high 100s. and no, guess i miswrote it. gear oil does NOT equal trans fluid!!! (in 95% of cases, i thnk toyotas and maybe the sn95 mustang take gear oil in the tranny, but not too sure) ( i meant != which is does not equal in python.. but i messed that one up, argh! chances are i was thikning about the equals sign with the slash thru it... in algebra
) trans fluid is the red stuff, egar oil is much more viscous, and has a sulfur smell. trans fluod should be changed every 30k imo (even tho ford said its lifetime, i don tbelieve in that!!!), drop the pan and change the filer, and when youre in there, add a drain plug, makes life so much easier!!! and i change my f/r gear fluid every 30-40k, but thats excessive, only cause i go thru the water and i tow/offroad. for normal use maybe 50-60 should be fine. just suck the fluid out through the fill plug, and add. if youve got an LS rear end make sure to add the ls additive. they make covers with drain plugs, but never tried one yet
