Jim Galloway
- June 20, 2001
- Stuart, Fl
- Explorer 93 XLT
changing u joints
changing the u-joints is easy. should only take you about an hour. follow instructions from a haynes manual or something similar. first you will need to remove the drive shaft (i think you need a 12mm, 8 point socket/wrench). then, just bang out your old joint with a hammer and small diameter socket (be sure to remove the retaining clips first). you may really have to give it a pounding. if you have access to one, it would be easiest to use a press to remove the old joint. put the new one in and put the drive shaft back on. it's that easy.
if you have any play at all within your ujoints, you should replace them. when you check to see there condition, really muscle that driveshaft around in all directions to see if there is any play at the joints. that drive shaft is damn heavy, so even if your ujoints are shot to hell, they may seem fine... you really need use some force when you try moving the thing around to check for excessive play. good luck!
