Here are more ideas: ball joints, bearings, bushings, shocks, springs, fuel filter, PCV, O2 sensors, U joints, fuses, relays, engine, transmission, transfer case, seats, interior, lights, stereo (the list could never end).
Ball joints - Thinking about doing when I do shocks in a couple weeks but might wait till they break or squeek
Bearings - Ill do those as they wear out as well
Bushings - I might do those when I remove the front axle to replace the front differential cover
Shocks - Couple weeks, short on cash
Springs - arnt any on my truck
Fuel filter - I have one im waiting to fill the gas tank and run it out before I replace it
PCV - I need to look up where it is but thats very doable
02's - I need an exhaust and ill shoot removal of all those components
u Joints - I think I need u joints and both drive shafts so that should be fun
Fuses and relays - I can show the fuse box location and what a blown fuse looks like, sounds simple
Engine Trans Trasfer Case - Ill only tear into those if I have to, only 86k so prolly not anytime soon.
Lighting - I might be putting a brush guard with a winch and some PIAA lights or something we will see. If I do it ill write it up for sure.
Audio - There will without a doubt be a full audio installation radio, wires, door speakers, speaker box, subs, amps, the whole 9 yards.
Thank you very much for your suggestions, ill do all of them that I can. I would like to do as many front end parts as I can before I get an alignment but they are expensive. Keep the suggestions coming!
