Slybarger
- August 17, 2003
- Granite City,IL
- 93 XLT 4 Door
Slybarger said:
Charlie's_93EB said:and i just today got the same steel at the home depot for the rails
IZwack said:i'd suggest that u stay away from home depot and other home improvement stores for ur metal needs cauz its REALLY expensive there. i mean not so much when u need like 3 feet of something but once u start getting over like 12", the cost is just too much. try looking for a metal supplier around u or a salvage metal yard or something - this is where i found the cheapest metal. of course metal from these places are often rusted but its worth it.
Charlie's_93EB said:Oh and can you tell a little more clearly explain the bending the tubing?
and how much was the exspanded metal?
thank you very much!!!!!!!!
Savage Wolf said:is there a salvage metal yard in the MD area?
IZwack said:hellow fellow marylander -
the place where i get my steel from is 'Standard Supplies Inc' and their website is: http://www.standardsupplies.com
the place has more than one department and to get to the steel yard info, once you're at the website, click on Locations, and then its the "Steel" location.
just to give you a general idea of where its located, do you know where the Montgomery County Agriculutural Fair takes place every year (a.ka. the "Fair Grounds")? Its like a walk from there. another big place that you might know around the area is the "Lakeforest Mall" - thats like 3 or 4 blocks from the Steel location.
but tell you what, you give me that Atlas and i'll give you enough steel to make you're "shop" fixtures
Slybarger said:Basically I used 3 peices of 3/4" plywood sandwiched together with the center board cut to the desired bend. (In my case I used a 12" bucket as a pattern) Drill a hole for a single bolt, to serve as a pin, to hold the tubeing in the bender. Then just attach a handle however long you need for leverage to bend. I bent everything cold so the handle was about 3ft long.
Oh the expanded metal was $40-50 for a 4x8 ft sheet from local metal supplier.
GOOD LUCK WITH THE BUILD --Sly--
Savage Wolf said:Thanks for the info, might almost have a deal with the atlas seeing that I'm planning on building a 60 ton press brake about 4-5 feet wide
Charlie's_93EB said:ya i was thinking about useing EMT, but i was at the metal store first, supporting the little guy.
but the prob with round tubing is you can get a perfect 45 on one edge, but the other side is tricky b/c it may twist. and you will have to notch every crossmember.
but do not get me wrong i will be useing EMT a lot in other places
