Blown
- December 6, 2007
- Montrose, CO
- 2000 X-Edge
Naw, nope, not ready to run E85. I got to get-out and find some E85 and test it. I think the closest pump is 5 and half miles away. Finding E85 and testing it is a bit of a pain. I am concerned with cylinder lubrication, so will probably run a mix of E85 with gas. I am going to do some more research, but I think that will get me the octane needed and lubrication for the upper cylinders. I have seen that many running E85 use an additive and mixing gasoline will be cheaper as it already has the additives.
My build is currently at a bit over 9lbs of boost on 91 octane Premium (highest available in Denver) with a bottle of Lucas Octane added. I estimate 380hp and 455ftlbs of torque on this mix of fuel. She pulls hard and the blower howls louder!
My power estimates are at 408hp/485ftlbs with a true 85% ETOH E85 mix...................................................................another 28hp/30ftlbs is noticeable, but really not that much if finding E85 and mixing is a pain. A 50/50 mix may not allow the timing to be as aggressive, if so there would be less power........................................taking my time with this.
