J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
Do I really need Warrior 153 shackles? They're out at Amazon, now $110+ everywhere else before even considering the bolts and bushings... bolts I can find anywhere, but I don't see a lot of people talking about the bushings, apparently they hadn't gone this long in a salted winter environment?
I will likely need frame to shackle bushings, maybe even spring to shackle bushings. Is it really going to be $50 each or a ~$70 Energy Suspension kit just to get bushings? That seems like a lot of money for a piece of rubber with a steel sleeve inside and out.
It seems really expensive for what they are, then I see these ebay kits that include the (frame to shackle?) bushings for around $40. Is it really going to be cheaper to get an entire kit and reject the shackles themselves just to get bushings out of them?! Or if I don't expect the tour of duty on the shackles to be a decade because rust will do the rest of the vehicle in before then, use the shackles too?
NEW REAR LEAF SPRING SHACKLE REPAIR KIT PAIR SET FOR FORD EXPLORER MOUNTAINEER | eBay
Then there's the following, which I'm sure aren't as good as the Warriors, but it's just two steel plates with holes, how bad could they be?
Rear Shackle 1.5" Lift Kit Explorer 95-05 2WD 4WD | eBay
I don't really need a lift, but am already getting one from rear coilover shocks to help a sagging rear end, so a little lift from the shackles would ease the preload on the upper shock crossmember... it already broke the lower shock mounts (80% due to rust I'm sure but the extra weight on them couldn't have helped) which were recently replaced, but the shock upper crossmember isn't such an easy bolt-on replacement when the part doesn't exist, would have to be fabricated.
Then there's the make your own option, which I could do but then I'm still probably needing the bushings. Should I just get the $40 ebay shackles linked above and put them on, then swap them out later if they rust too much? Would these Prothane 6-810-BL, specified for '91-'94, fit the frame to shackle position?
Prothane 6-810-BL Rear Frame Shackle Bushings 91-94 Explorer/ Mazda Navajo-Poly | eBay
