itzbinnice
- May 14, 2001
- Long Island, New York
- 95 Xlt Black
My 95 XLT has 70K original miles, bought the vehicle used in 1998 with 30K miles. I live in the North East with winter temps frequently dropping below freezing.
For the past 3 winters I have noticed the tranny will not shift from 2nd to 3rd gear until the vehicle was driven for some time and the temp gauge would move to about the 1/4 mark. It would hit 40 mph and rpm was at about 2100.
When warmed, at 40 MPH, it would shift and stay at the 1500 to 1600 mark when hitting 3rd. Other than the winter months, the tranny always shifted fine.
Recently the OD light came on and I tried re-setting 3 times and always came back. Brought it to a reputable Tranny shop, 2nd gear band was shot and had a rebuild done. He told me he would be installing a shift kit and down shifting may be a bit harder. He was right, it bangs going from 2nd to 1st. I called him and I will be bringing it in on Saturday where he will drop the pan and make some sort of adjustment to the shift kit spring.
Now the real problem, it still has the same symptoms of high RPM (2100) and not shifting from 2nd to 3rd until warm. I discussed this with the mechanic and I will be dropping the car off Friday night and let it sit overnight, then I will meet him in the morning and we will road test when completely cold.
Furthermore the temperatures has been rather mild lately, 40 to 45 degrees and it still behaves this way.
Reading the owners manual, it does not give specific shift times and RPM, it did say:
"For Example, you may notice that the transmission will upshift to a higher gear to a higher gear more quickly when the vehicle has not reached normal operating temperature"
This is just the opposite of how mine behaves. I discussed this with the mechanic and he said the outside ambient temp has nothing to do with the shifting, but rather the tranny temp itself. I disagree with him, I would assume if the outside temp is 50 degrees the tranny would warm up far faster than if it was 32 degrees. I am thinking perhaps it was, and still is, a defective Throttle Position sensor or Engine Speed Sensor that is causing it to behave this way. I'm concerned because I don't want this to damage my newly rebuilt trans. I'm wondering also if it could be a defective Powertrain Control Module.
The mechanic appears to stand behind his work and will check codes after our road test on Saturday. Can somebody please advise how their 95 XLT shifts from 2nd to 3rd in cold weather. Also I'd appreciate any input for suggestions of why it is behaving this way, as well as the mechanics statement about ambient temp having no effect on shifting.
Thanks in advance for any replies.
